Example Code
Using a Multiple Selection Listbox
Products and Environment
    Software
  • LabVIEW
    Programming Language
  • LabVIEW G
Code and Documents
Description
This VI allows the user to use a multiple selection listbox to perform several tasks. For example, if there are several tests that can be run, this VI will let the user choose multiple tests that will be run in sequence.
Comments
SuperDuperCooper
Member
Member
on
Can't open this vi on LV2015 ... error is vi is too old to convert (LabVIEW 4?)
crossrulz
Knight of NI Knight of NI
Knight of NI
on
I just updated the VI to be saved in LabVIEW 8.0, which can be opened in any newer version.  I also did some re-architecting to use an Event Structure (did have a polling greedy loop), and auto-indexing tunnels.
Contributors
