Introduction
If for any reason a user wants to use a password-protected Excel template for Report Generation the ability is not baked into the Report Generation Toolkit. In order to workaround this we need to step down through several subVI's and make password input available, implementing it with a Functional Global Variable.
Steps to Complete
1. Setup subVI to use password.
a. Navigate through subVI's to Excel_Open_Workbook.
b. Import pswdGFV.vi and wire through Convert to Variant to both the password and writeResPassword.
c. Save and close.
2. Implement pswdGFV.vi on main VI and set password ensuring to run this VI before the rest of the application.
Jey.. it s really good.... Thnks for your invention.....
Which ones? Most of them come with the Report Generation Toolkit and the ones that I edited are attached below the explanation.
Thank you sir for the code.....iam having one doubt..in PswdFGV.VI (which is added as subvi) error line is not there coming out of it i..but in snapshot it's there....from where you have taken that...please help
