Using property nodes with an array of clusters Using LabVIEW
Overview
This example VI modifies an element of an array of clusters using explicit property nodes.
Description
 When I try to use the 'value' of a property node containing an array of clusters the entire array is returned, or if I use the array element, it is returned as a variant, how can I get a specific element from the array?
You can use this code to this to return the modified element of an array containing a cluster.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the code.
  2. Change some of the values in the array.
Additional Information or References
VI Block Diagram
