Overview
This simple project would use module of Synchronization to route the signal
Description:
This example demonstrates how to synchronize two 9234’s by manually share a Sample Clock Timebase, Synchronization Pulse, and Start Trigger between two cDAQ controllers or chassis using an NI 9469.
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 9.0 or compatible
Hardware
cDAQ with C series Analog Input (NI 9234 (2)) and Synchronization (NI 9469 (2)) Module
