Example Code
Using the TestStand API to Add Items to the Templates List
Products and Environment
    Software
  • Teststand
Code and Documents
Overview
This example shows how to programmatically create new Step, Variable, and Sequence templates in the sequence editor using the TestStand API.
Description
In order to create new templates, this example completes the following steps:
  1. Access the Templates file using the Engine.
    Locals.templatesFile= RunState.Engine.GetTemplatesFile(0)
  2. Use the PropertyObjectFile method to access the data within the templates file, and add the new template items as subproperties.  Use the clone method to create a new instance of the new item to be used as a template.
    Locals.templatesFile.AsPropertyObjectFile.Data.Root["Steps"].SetPropertyObjectByOffset(0,1,RunState.SequenceFile.GetSequenceByName("Template").GetStepByName("Test Step", StepGroup_Main).AsPropertyObject.Clone("", 0))
  3. Increment the change count of the file.
    Locals.templatesFile.AsPropertyObjectFile.IncChangeCount(),
  4. Refresh the window to update the templates pane.
    RunState.Thread.PostUIMessageEx(UIMsg_RefreshWindows,0,"",Nothing,True)
Hardware and Software Requirements
Dynamic Template Insertion - TS2012.seq
TestStand 2012 or Compatible
Dynamic Template Insertion - TS2016.seq
TestStand 2016 or Compatible
  1. Open the attached sequence file, and execute it using Execute » Run MainSequence.
  2. Once the sequence runs, observe that the templates have been updated in the sequence editor.
Manooch H.
