Description
Description-Separate-1The code attached to this example shows how to implement two different buffers using a sweep mechanism to update the values in the table. The data is generated randomly, but it represents the acquisition of information using real hardware.
There could be multiple ways to show the data differently in the table. The easiest approach seems to be implementing a case structure and functions related to the string manipulation palette like the replace string. This example shows a way to avoid using these functions in order to make sure that the developer handles the acquisition data in separate allocations in memory. Therefore, logic or post-acquisition steps can be applied independently to each buffer before displaying the data in the table indicator.
Description-Separate-2
