Example Code
Utilizing Command Prompt using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This simple program utilizes command lines along with the System Exec function to allow the user to shut down, restart, log off and access the shutdown options windows dialog.
Description
User event based programming with an event case for each of the buttons on the front panel. In each case the System Exec function is used to send a system command to the command line application. This tool could be usefully integrated into VIs where the user does not get access to windows or integrate to programmatically shutdown our LabVIEW application upon completion.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Download the attached VI to your computer
  2. Open the VI "Shutdown 2012 NIVerified.vi"
  3. Run the program
Additional Information or References
VI Front Panel
VI Block Diagram
Aaron. E
Product Performance Engineer
Dyson
