Example Code
VI Block - DEMULTIPLEXER 3 Inputs_ 8 Outputs
Code and Documents
This VI simulates a 3 Inputs DEMULTIPLEXER.
Changing the states of the 3 Inputs values​​, you will get a HIGH signal to one of the 8 equivalent Outputs.
B0 as the lowest Input value, follows B1, B2.
Enable switch.
Y as the Output.
N° shows which of the outputs assume the high value.
Follows the truth table:
B2 B1 B0      Y      N°
0   0   0         H      0
0   0   1         H      1
0   1   0         H      2
0   1   1         H      3
1   0   0         H      4
1   0   1         H      5
1   1   0         H      6
1   1   1         H      7
Mattia Perazzelli
Student at I.T.I. Guglielmo Marconi
Campobasso - Italy
Electronics and Telecommunications
Contributors
