Example Code
VI converts text to string array
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
Converts A multiline string into an array separating each line.
Description:
This code makes usage of the spreadsheet string array. Wire a feed line constant to detect each change of line and a 1D array desired dimension. The array subset converts the array to the right side avoiding an empty line at the end.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Run the VI
2. Change the text string or use as a sub VI.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
