Overview
Very simple video capture and preview example. While obsolete by today's standards and might not be supported in future versions of windows (works fine on W7 32/64 bit and below), can be still usefull when simple frame grabbing required for quick inspection, OCR and such.
For more advanced video capturing needs native DirectShow required, which is on its way to be replaced by media foundation...
The windows you create by using the AVICap window class (avicap32.dll) can perform the following tasks:
Description
Features:
Attached library provides guide lines and working example on following:
Cons:
Pros:
Open WM_CAP - AM Capture.vi from attached llb. library and click "RUN" button.
Requirements to Run
Software
Hardware
Additional Images
-Artur
Is there a version for LV2009?
Attached...
Thank you. I will dowload it and try.
Opening AM Capture I found it broken.
Missing object. The object "Start Asynchronous Call" does not exist in the previous version.
Fixed, sorry for delay,
-Artur
I know this is quite old thread, but is there anyone that was able to make it work in Windows 10?
Benoit
