by:
03-10-2015
06:17 AM
migration-bot
11-13-2023
08:10 PM
Products and Environment
Hardware
- VirtualBench All-in-One Instrument
Code and Documents
Description
Description-Separate-1Overview
This example automates the digital input output (DIO) channels to master SPI commands and performs a read.
[+] Enlarge Image
Steps to Run Program
- Download the example program on the right under downloads.
- In LabVIEW software, open the program by going to File » Open… and navigating to the file.
- Connect the VirtualBench device.
- Select the correct VirtualBench bus channel from the pull-down menu of the VirtualBench Bus Channel control. Set the clock rate, clock polarity, clock phase, and chip select polarity; specify the data to write
- Click the Run button to write and read data.
- The data acquired will display in the Results indicator.
Program Explained
[+] Enlarge Image
- Initialize Session
- The VirtualBench bus channel is passed into the SPI Initialize VI to initialize a new session on the SPI engine for the device.
- A Boolean true constant is also passed into the VI to reset the device to default values.
- Configure Instrument
- Instrument and error information are passed into the SPI Configure Bus VI along with the clock rate, clock polarity, clock phase, and chip select polarity.
- Perform Operation
- Instrument and error information are passed to the SPI Write Read VI.
- The data to write is also passed into the VI, and then the VI performs a write followed by a read.
- The VI then outputs the data read to the indicator on the front panel.
- Close Session
- The instrument and error information are passed to the SPI Close VI. This closes the session and deallocates any resources for the next time a session is created with the instrument.
- Handle Errors
- Finally, the error information is passed into the Simple Error Handler VI. If an error has occurred, a dialog box will open to notify the user.
Additional Resources
VirtualBench Examples
- Single Instruments
- Multiple Instruments
Description-Separate-2
