Example Code
Waveform Plot Color Change Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example displays a random waveform that continually displays 10 seconds of data at a time and changes the color of the main plot if the waveform crosses a threshold.
Description
The VI generates a random waveform and show the plot on the waveform chart. In the meantime, it checks if the waveform reaches the upper or lower limits, and changes the color of the plot if it happens.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
  2. See how the color of plot 0 change when it hit the upper or lower limit.
Additional Information or References
 VI Snippet of Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Joel I.
