Overview
Coding that exemplifies how to create a subVI that generates an XY pair out from the time stamp and values of a waveform.
Description
This VI allows the user to output a waveform as XY pairs where each Y is associated with a timestamp. It also allows the waveform to be output as an array of doubles where the timestamp is replaced with an initial start value which can be set by the user. Each value of Y has an associated X value based on that initial value and increments with the change in t or dt which will be taken from the waveform or set by the user. The user is also able to select whether the first column is X or Y.
Requirements
LabVIEW 2012 (or compatible)
1. Configure the t0 and dt if desired.
2. Select the order for the XY pair.
3. If you do not want to use it as a SubVI, we can use a simulated signal and wire it instead of the "Waveform In" control.
4. Run the SubVI.
Additional Information or References
While this does give the user a little more choice, there is the Waveform to XY Pairs.vi in LabVIEW.
