This VI is a small project I put together to monitor a web page, and notify the user when it has changed via multiple methods including pop up dialog, opening the page in the default browser, and sending a text message to a list of recipients. I originally created it for buying concert tickets that were a very hot item. The tickets sold out within 3 minutes, and I was one of the few people who got them.
The VI is pretty straightforward to understand. Simply open and run the Web Site Notifier.vi. If this is the first time using the VI you will get a pop up asking for the site URL and parameters to filter (See Filter Text (Variable) for information on this).
Then the main window will open allowing you to set options such as the Refresh Rate, dialog timeout and Text message options.
When the page in question changes, you will first see it pop up in the default browser. This will allow you to make sure that it was the real update you were looking for and not a false alarm.
At the same time as the browser opening, a dialog will pop up asking you if the URL is real or fake. If you select fake, nothing will happen and the program will continue to check the page again. If you select Real, it will send a text message to anyone on the announcement list. If no response is select within the "Dialog Timeout" time limit, then the program will assume that it's real and you are too busy buying your tickets to care about a popup. It will then automatically close and send the text message.
If the change is real or the user hasn't selected an option within the Dialog Timeout limit, the program will automatically send a text message as configured in the Text message options.
Thanks to CaptainKirby for his Mass SMS Message Example and A_Patel for his Woot Off Checker
It would be nice if you could change the website you're checking without having to go delete the sitechecker.file
True. There's probably a lot of little things I could do to fix this up after looking at it for the first time in a year. To be totaly honest, it was a very quick coding project I put together last year to buy ACL tickets, so feel free to make changes and add it/update it here...
Ha, that's exactly why a couple of us in RIO are trying it out ![]()
