Overview
This VI is to programmatically check the bitness of Windows that are currently being run. If the operating system is 64-bit, the VI will return TRUE.
Description
This VI makes use of registry functions and Windows commands to determine whether or not the operating system the VI is run on is 64-bit. This is usually difficult to achieve in LabVIEW, which can only return the bit type of the runtime engine that is running.
Requirements
Additional Information or References
VI Snippet
You can also use the TARGET_BITNESS symbol with a conditional disable :
Hi D*
The Target_Bitness is a compile time variable that only returns the bitness of the compiled code. It will not tell you the bitness of the operating system you are running on.
Kind regards,
Matt
Over on LAVA a way was posted that doesn't rely on the registry, the command line, or the spelling of Program Files (x86).
http://lavag.org/topic/14002-determine-32-or-64bit-os-windows/#entry84338
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
