Example Code
Write AVI File with New Color Palette
Products and Environment
    Software
  • LabVIEW
  • Vision Development Module
    Driver
  • Vision Acquisition Software
Code and Documents
Description
Overview
This example turns grayscale images into a different color palette and then writes the new images to a AVI file.
Description
In LabVIEW, we can easily view a grayscale image in a different color palette by simply selecting the color palette on the Image Display indicator itself.  We can also modify the images to contain the new color palette information, allowing us to create AVIs with the new display.  In this example, we turn a grayscale image to an array of pixel values, which we then replace with the corresponding values from the selected color palette.  After that, the array is turned back to an image and the frame is written to the AVI.
  1. Download the VI
  2. Specify a camera in the Session In on the Front Panel
  3. Select the AVI Path
  4. Run the VI
Requirements
Software
LabVIEW 2009 or later
NI Vision Acquisition Software
NI Vision Development Module
Hardware
Compatible camera
Please see the following link to determine if your camera is supported
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Cole R.
Software Engineer
Comments
Gregory
Trusted Enthusiast
Trusted Enthusiast
on
