Example Code
Write Different Portions of One Waveform to a TDMS File in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI exemplifies how to differentiate different portions of one waveform of data when writing it to a TDMS file.
Description
Sometimes it may be desired to differentiate different portions of one waveform of data when writing it to a TDMS file. This method assumes that the data has been divided such that each index of an array contains one portion of the waveform. It then changes the name of the channel each iteration to differentiate each portion of the waveform in the TDMS file.
There is a relevant KnowledgeBase article here: KnowledgeBase 4TPGCIV7: Writing Different Parts of One Waveform to a TDMS File.
Requirements
LabVIEW 2012 or compatible
1. Run the VI.
2. Review the TDMS file on the TDMS File Viewer Window.
Additional Information or References
Jeff | LabVIEW Software Engineer
