Example Code
Write LabVIEW Class Data to an XML File
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI populates the data fields of a class and then flattens the object to an XML string and writes the XML string to a file.
Description
Once a LabVIEW class has been instantiated as an object that object has a set of data associated with it. That data can be flattened to an XML string and then written to a file. This example demonstrates the ability to write class data to disk for data storage purposes. See here for an example on how to read the class data back into LabVIEW after it has been written to disk.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the project and click the VI
  2. Run and view the results.
Additional Information or References
VI Block Diagram
Comments
D*
Member
Member
on
Does this handle escape characters?
David-A
NI Employee (retired)
on
Not sure what you mean by 'handle'. You may need to right click your string control and change the display mode to " '/' Display Codes " to get the behavior you are looking for. Reading up on what LabVIEW means by flatten when it Flattens To XML may also answer your question.
Backslash ('\') Codes Display
https://www.ni.com/docs/en-US/bundle/labview/page/backslash-codes-display.html
Flattened Data
https://www.ni.com/docs/en-US/bundle/labview/page/flattened-data.html
