Example Code
Write to File Every N Samples of Continuous Acquisition
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example uses DAQ Assistant to acquire data continuously, and writes the value to a Measurement File at a specified interval.
Description
The original application was to allow for the data to be monitored continuously for many hours, without creating a datalog of thousands and thousands of points. This way, you can specify every nth points to be logged.
Requirements
Software
  • LabVIEW 2012 or compatible
  • NI-DAQmx 9.5.5 or compatible
Hardware
  • NI Multifunction DAQ Device
  1. Configure the parameter for the right channel and device.
  2. Connect your hardware appropriately.
  3. Run the VI.
Additional Information or References
Product Support Engineer
