Example Code
Writing Special Characters to a File Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This simple example demonstrates how to write a special character (ie. symbols, special letters, shapes, etc.) to a standard text file using LabVIEW.
Description
This example uses the underlining fact that all characters have a Unicode format as representation.
The idea of this example is to use "reverse engineering" in order to determine the Unicode format of the particular character you are trying to acquire. Once the Unicode representation is obtained, use this newly obtained code to write the corresponding character to a file.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Insert a character a new text file. Save the file
  2. Create a blank text file and save it. This will be the file that you will be writing to
  3. Change file names on the Block Diagram that you want to read/write from
  4. Run the VI
  5. Copy Unicode Representation obtained in the "Character read from text file" block, into the "Writing to text file" block
  6. Run the VI again
  7. Open the text file that the character is being written to
Additional Information or References
VI Snippet of Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Rob W.
