Example Code
Writing To a Header In a Word Report
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This example shows how to add data to the header of a Word report. The VI inserts the data into a Word template that has a table in the format of a header. After the data is inserted into the table, this VI runs a macro. The macro moves the table into the document header.
To use the attachment, extract all the files into the same directory. When you run the ChassisTestAutomatic (version) VI, it opens TestPlan.dot, which has the macro in it.
Related Links:
LabVIEW Report Generation Toolkit for Microsoft Office (now included in LabVIEW Professional)
