Overview
This example creates a debugger that has ALL the VI references by obtaining the This VI Reference and registering it with a central system as soon as execution begins.
Description
You can put this XControl on the front panel of a VI that you want to register with your debugger and you put the code shown on the block diagram of Reentrant.vi on the diagram of whatever VI you want your debugger to be capable of monitoring. This specific pattern of code forces the panel into memory, without opening it, which gives the XControl a unique panel existence. You can also put the same code on a reentrant VI or a non-reentrant VI, so there's no worry about changing types.
Requirements
Additional Information or References
VI Block Diagram
ceci n'est pas un chaton? ![]()
