Example Code
XY Chart With Buffer, Multiple Plots, and NaN Capability
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to build an XY Chart effectively rather than an XY Graph (Graph requires an array to plot all at once, Chart remembers history, takes 1 sample and adds it on to the end), and is able to also handle NaN values.
Description
It can generate NaN values by setting the bool leans to true. Click them again to return to generating random values.
You can increase the period to display in min while the VI is running, but you must restart the VI to apply a change to chart length
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run VI.
Additional Information or References
VI Block Diagram
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
Comments
Aaron_KZ
Member
Member
on
careful calling this a chart. the graph will redraw each plot every iteration, and if the plot history is large enough, the Front Panel can lag (especially on an old lab computer).
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/XY-chart/idi-p/2045138
