Overview
Sends serial commands to a Digi Xbee Pro RF module.
Description
Use the attached VIs to communicate serially with your Xbee device. The serial command has the format "ATCOMMAND*", where COMMAND can be found in the device's product manual.
Requirements
1. LabVIEW 2012 (or compatible).
2. Digi product that uses the AT command structure.
1. To send a command to your Xbee module, use the VIs in this order:
2. Enter-AT-Cmd-Mode.vi to enter AT command mode
3. AT_SetCmd.vi to send the command
4. AT_GetCmd.vi. to receive the information requested
Additional Information or References
Can you show a wiring sample of these?... I want to send Values from my joystick through my Xbee Pro S2B
This is my post... http://forums.ni.com/t5/LabVIEW/Send-Joystick-Values-through-Xbee-PRO-S2B-USB/td-p/2262742
Thanks in Advance ![]()
Yeah can i see the pinout for this?
I don't understand how it works.
If I want to read a digital input D0... is it right if the strings are "3" in Set_ATCmd and
string "D0" in Get_ATCmd???
Set_ATCmd: 3 (set to 3 if it corresponds to a digital input)
Get_ATCmd: D0 (AT Command for PIN0)
Do you have a VI for API mode?
