Example Code
Xbox Control UI
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example reads the buttons presses of the Xbox 360 controller connected.
Description
LabVIEW has a palette called "Input Device Control" inside this palette we can read value from the PC's mouse, keyboard or a joystick. the driver for the Xbox 360 controller allows it to be recognized as a joystick. This example has an image laid on the front panel and Boolean LEDs which would be lit when various buttons where pressed.
Requirements
  • LabVIEW 2012 (or compatible), Xbox 360 Controller, Xbox 360 drivers
  1. Connect Xbox 360 controller
  2. Open " Xbox Control 2012 NIVerified.vi"
  3. Run the program
Additional Information or References
VI Block Diagram
Kevin R
National Instruments UK&Ireland
Comments
damirce
Member
Member
on
Dear developers, I have problem with mention Joypad. First I was using MotionJoypad and with PS3. Emulation is ok. In LabView is working everything ok until now. I put USB in the same dongle, I can see in control panel axis moving.. Also I was buy wireless original XBox controller but no input detection inside example of Labview 2013.
dev. index is changed... I was try all..   OS is Win8.1 , LabView 2013 32 bit
damirce
Member
Member
on
How to change or add new driver inside system,... ctl from begining, I did not change anything.. Software from Microsoft works for original and emulated Joypad, I can start OSD status and green LED are on up left and up right. Emulation ok... but aplication inside LabView dont see device..
damirce
Member
Member
on
When I was install toolbox from LVH everything working ok.
I fix the problem.
Julian28
Member
Member
on
Tank you very much, this VI is very usefull
mattkreuz
Member
Member
on
i have windows 10, cant download required driver
richard77
Member
Member
on
damicre:
plis can you help me with the problem, bacause I have conected the xbox controller but labview doesn´t reconized it
Bin2022
Member
Member
on
I tried many examples, but even both (https://forums.ni.com/t5/Example-Code/Xbox-Control-UI/ta-p/3525774) and (https://forums.ni.com/t5/Example-Code/Xbox-360-LabVIEW-Interface/ta-p/3498186) not work.
I found my joystick worked in an online test (https://gamepad-tester.com), so the problem comes from the Labview driver or app.
Later I tried the following and then the above codes worked, for reasons unknown.
(1) I download the compatible Labview VISA driver (refer to https://www.ni.com/en-us/support/documentation/compatibility/16/ni-visa-and-labview-version-compatib...
(2) I assigned 2 rather than 0 to the device index to the Initialize Joystick VI.
