Overview
This example introduces the myDAQ PCB connector.
Description
The myDAQ PCB connector can be used to design and make custom PCB boards that can plug in myDAQ. The miniSystems use this part in its every design for myDAQ integration.
Requirements
NI Multisim 11 or compatible
NI Ultiboard 11 or compatible
Connector Availability:
The NI myDAQ 20 pin PCB mountable connector is available at $50 for quantity 25 by calling NI at 1-800-433-3488.
Use part number 781334-01 NI MYDAQ ACCESSORIES: 25 PCB MOUNTABLE CONNECTORS
Merging Database:
To add the PCB connector to your Multisim/Ultiboard Database, in Multisim go to Tools > Database > Merge Database. Select the corporate database attached and continue from there. The component will be in your Corporate Database, under NI_Connectors. Also check the video attached.
Some points to note:
Please find attached:
Multisim Schematic Representation:
Ultiboard Schematic Representation:
3D Representation:
