Example Code
 Barcode Reader and DAQ Events Using LabVIEW with DAQmx
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This VI is a simplified template of a larger application that dealing with DAQ Events.
Description
This is a template application that requires additional programming for it to work. There are a Barcode Scanner and a DAQ measurement (assumed AI - Voltage) of a device which are both triggered by the rising edge of a digital input (PFI Line).
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open “Barcode DAQ Events 2012 NIVerified.vi”.
  2. Use the VI as a template to start your project design.
Additional Information or References
VI Snippet
Joe Daily
may the G be with you ....
