Overview
This example will read a .csv file and display it in an array indicator.
Description
This example shows how you can use the read from spreadsheet file to pull data from a spreadsheet. In order to directly read Microsoft Excel files we need to use the Report Generation Toolkit (examples in Help»Find Examples), but in excel you can save a spreasheet at a Comma Seperated Value file (CSV) and you can read that using the Read from spreasheet VI.
While this example will not necessarily work for all formats of spreadsheets, it demonstrates the usage of the delimiter and should be a good starting point to build an application.
Requirements
Additional Information or References
VI Block Diagram
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
