Short example how to build LabVIEW and Python clients and servers.
LabVIEW server + Python client = control LabVIEW from Python
LabVIEW client + Python server = control Python from LabVIEW
Hope this is useful for someone. Have fun!
Thank you very much for useful video and files. Could you please include the missing typedefs for the TCP Multiple Connections - Server.vi to make it more complete?
I could include the typedefs but you can just disconnect them. I think that is faster and the code works the same. Sorry for not disconnecting them before puting them herehere.
Where is the .ctl of the TCP Multiple Connections - Server?? The arrow button is broken, I can't run it. Please do help. Thank you in advance
Fixed the CTL problem
Hi
I really enjoy using your program. I am getting a huge string before the data I need that looks like this \t\u0000\u0000\u0000\t\u0000\u0000\u0000\t. This is when I write it to a file. I am using the python client and labview server. I was wondering if you had an idea of how to remove this. I have tried .replace() in python but it didnt work. Thanks for putting this code up it helped out a lot
Check this simple...socket programming in python
I'm trying to do this LabVIEW server + Python client = control LabVIEW from Python
--------------------------------------------------------------------------- TimeoutError Traceback (most recent call last) Cell In[17], line 6 4 client = socket.socket(socket.AF_INET, socket.SOCK_STREAM) 5 server_address = ('169.254.201.53', 8000) ----> 6 client.connect(server_address) 8 for x in range(100😞 9 size = struct.unpack('i', client.recv(1024))[0] # Extract the msg size from four bytes - mind the encoding
TimeoutError: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
the above is the error i received from the script
