Examples and IP for Software-Designed Instruments and NI FlexRIO
I2C IP
I2C IP »
This IP implements inter-integrated circuit (I2C) communication, including support for both master and slave functionality.
Description: Inter-Integrated Circuit (I2C) buses are commonly used to communicate between a controller (master) device and a target (slave) device. I2C buses require two lines for communication: clock (SCL) and serial data (SDA). This IP contains LabVIEW FPGA code for both an I2C master and an I2C slave.
Additional Documentation:
  • After Installation - C:\Program Files (x86)\National Instruments\LabVIEW 2012\user.lib\_NI I2C IP\documentation\NI 5644R Inter-Integrated Circuit (I2C) Example.pdf
Compatibility:
Dependencies:
  • none
Performance:
  • 7 and 10 bit addressing
  • Up to 8 data bytes
  • Read and write access
  • Programmable clock frequency
FPGA Footprint:
Xilinx Virtex-6 LX195T
  • 0.7% / 839 LUTs
  • 0.4% / 907 Flip-Flops
  • 0.0% / 0 Block RAMs
  • 0.0% / 0 DSP Slices
  • 40 MHz clock rate
Latest Version:
Previous Versions:
  • none available
Note: All source on this community is distributed using VI Package Manager (VIPM). For more details on VIPM, please read A Note on VI Package Manager
Ryan Verret
Product Marketing Engineer
Signal Generators
Comments
mi-ni
Member
Member
on
I would like to use your I2C IP, but we need combined transfer format.
As far as I see, the implementation 1.3.0.1 (distributed via VIPM) does either read or write after the addressing of the slave.
Combined format uses the I2C repeated START condition to combine write and read interaction with a slave (e.g. ADC).
Here you often need to write a configuration for a channel and then read the result after repeated start.
Do you have a version in preparation with support of this feature or can you give a hint, where we can easily change the state machine?
Thank you & greetings
  Michael
ZY_Ong
NI Employee (retired)
on
Does anyone have idea what is the missing portion for R Series - NI I2C FPGA Simulation - Host.vi?
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
UMASO
Member
Member
on
Hi, I had the same situation and below was what I did to make it work.  Hope this helps!
MattFitz
Member
Member
on
The image of the code was beneficial!!  I tried to add an updated version for the NI USB 7856R FPGA.  No attach file option 😞
sz007
Member
Member
on
I'm trying to use your I2C IP with NI sbRio 9628. The sbRio doesn't support The Set Output Enable within a timed loop.
Is there a way I can adapt the example to work with this specic sbRio.
