NI Instruction Sequencer IP »
This IP contains a memory to hold sets of instructions, called sequences, which can be issued from the IP on the FPGA to another component on the FPGA, such as a digital protocol generator. This facilitates FPGA-based reconfiguration.
Description: This IP contains a memory to hold sets of U32 data values, or instructions. Instructions are grouped into sequences, and there may be one or more sequences in the memory. Events on the FPGA cause an entire sequence of instructions to be sent to the downstream IP, accommodating back-pressure or flow control. After a sequence is generated, the IP advances to the next sequence in the memory. Once all sequences have been generated, the IP returns to the first sequence, enabling looping.
Additional Documentation:
Compatibility:
Dependencies:
Performance:
FPGA Footprint:
Xilinx Virtex-6 LX195T:
Latest Version:
Previous Versions:
Note: All source on this community is distributed using VI Package Manager (VIPM). For more details on VIPM, please read A Note on VI Package Manager
