FIRST Robotics Competition Discussions
2012 WPA key?
After realizing some minor stupidity on my part (I only did the 'True' case for when a button was pressed, causing our robot to never stop rotating) I (think) I've solved the issue, and I would like to deploy the code and see if I've fixed the issue. However, an out-of-controll robot and a short LAN cable don't go together well. Does anyone know happen to know what the WPA keys are this year? I know last year is was '<Team#>WPAKEY' but that doesn't see, to work. If I had thought about it I would have poked around during competation and snagged a handshake, but that could take more years than I would be alive to crack. Any help would be appreciated. I would like to keep with whatever password we currently use, but any solutions would be better than what I have now!
(4,549 Views)
I'm not aware that the WPA key assigned at competition was ever guessable. The best thing to do is log into the radio directly and set the WPA key to something you'll remember. Why do you want to keep the key assigned at competition?
Message was edited by: sciencewhiz
(3,088 Views)
