FIRST Robotics Competition Discussions
2015 Drive Station
How can I change which dashboard opens with the drive station? I have a dashboard that I'm trying to open, but it keeps opening the default dashboard. How should I fix/change this?
(3,880 Views)
If you open your desired dashboard independently as its own application and then you open the driver station, the opened dashboard should be able to run. Otherwise, there is an option in the driver station called "window" that has an arrow button next to a box button. If you click the arrow button, you should be able to switch the dashboard to your desired one. GOOD LUCK!
(3,235 Views)
