FIRST Robotics Competition Discussions
2017 vision example missing calculate particle scores vi
Hi
when i open the labview vision example 2017 in the vision support code im missing the calculate partical scores.vi where is the vi located so i can point the project explorer to the vi. it is on a windows 10 computer. i can find the 2015 and 2016  calculate partical score vi in there folders but not in the 2017 folder  C:\Program Files (x86)\National Instruments\LabVIEW 2016\examples\FRC\roboRIO\Vision\2017 Vision Example\Vision Support Code
(4,296 Views)
It will take a long time, but you can try re-downloading and reinstalling (don't forget to uninstall first).
(4,207 Views)
i am taking a guess here but i think the problem was that we did not have a serial number for kickoff and the install required the serial number to install the vi. all i did was reinstall the software and it seems happy now.
(4,202 Views)
I was getting a similar error, but we were getting pixel data but the distance calculations always was "inf".  The target detection was always red, but we were getting a very good mask. I was using a Laptop (Windows 10) with last year's version still installed.  I uninstalled all versions of Labview and did a new install last night.  I'll let you know if this fixed the problem tonight.
(4,189 Views)
Sorry to say this but it's not working still!!! Multiple different downloads from various students and the vi is still missing reinstall did not work.. ni please fix
(4,184 Views)
I have a presentation using this example so I took some time to figure it out.
If you right click the Calculate Particle Scores.vi and go to Find -> Callers it should say "No items were found." This means that the VI is not being used in the project.
Next Right click it again and click "Remove from Project"
It will give a warning but it is ok.
As far as I can tell, it looks like someone coppied the 2016 Example and then forgot to remove the referance in the project after they deleted the physical file.
I have done this and was able to get the example project to work on the roboRIO.
If you want to see me do this live feel free to join us tonight 5 - 7pm Central time for a webcast on how to use this example with your robot.  Here is the link for the webcast: https://techjoynt.zoom.us/j/4053455010
If you are in Oklahoma, we will be at the Gordon Cooper Technology Center in Shawnee, OK Room D60.
I will post a link to this webcast once we get it posted.
(4,154 Views)
