FIRST Robotics Competition Discussions
Analog board 2 - Sensors
I see that for specific sensors (gyro, etc.) the Typedef is limited to the Analog Module #1 only.  Is there any technical reason that I cannot change this to include Analog module #2 so I can use those sensors on the second board?
(3,763 Views)
There are only two hardware accumulators that perform the integration of the gyro rate to give position built into the fpga, and they are on analog inputs 1 & 2 of module 1. If you want to just get the rate from the gyros, you can use analog vi on either module.
(2,943 Views)
