02-12-2011 07:06 PM
We are having a problem with the Robot code. After deploying the code, the system works but after we turn off the Robot power supply and restart it, the driver station indicates NO ROBOT CODE. Need assistance.
02-12-2011 10:02 PM
Did you right-click on the cRIO target and choose "run as startup" ?
02-14-2011 12:01 PM
Also make sure the cRIO switch is set to the correct setting which will allow the code to boot up during startup.
Bill
