FIRST Robotics Competition Discussions
Code Deployment
I'm sure it's because it is bag day!  How do we keep the latest robot code on the roboRIO and available when we reboot the robot?
(4,344 Views)
If you expand the "Build Specifications" section of your project, there's an option for "FRC Robot Boot-up Deployment"  You'll want to build that and deploy it to your roboRIO.
If you didn't see this before you bagged your robot, you should still be able to deploy your code when you get on site even if the robot doesn't boot up with the code already running.
(3,499 Views)
