FIRST Robotics Competition Discussions
Dashboard not showing up.
I have configured everything and the driver station has worked flawlessly until it randomly decided to stop loading the top part. We ended up restoring the whole classmate, then it worked fine again. But the dashboard just stopped loading again. Although, I can open it from the developer account, but I really dont know what I need to do to fix the issue.
I get no errors.
(3,902 Views)
In the setup tab, did you select remote dashboard?
(3,054 Views)
yes i did.
(3,054 Views)
When you select remote dashboard, the local dashboard isn't started. You can choose local dashboard and then restart the driver station software to get the dashboard back.
(3,054 Views)
