FIRST Robotics Competition Discussions
Deploying the default advanced or basic FRC Labview projects do not complete successfully
After pressing "Run" to deploy either the Advanced or Basic FRC cRIO Robot Project, the "Deploy..." window is displayed and status messages scroll by in the Deployment Status box.  The progress bar appears to reach 100% but we never get a complete message.  After reimaging the cRIO with V7, the first attempt always results in the messages:
Deploying Basic Robot Main.vi (37.04K)
Deploying Acquire Image.vi
Deploying Autonomous Independent.vi
Deploying Robot Main.vi
Deploying Send Images To PC.vi
Free Memory 21447K of 61087K Total (35%)
The deployment freezes at this point.
After power cycling the cRIO, on the second attempt to deploy results in the last message of:
Free Memory 21642K of 61101K Total (35%)
and then it freezes.
Third attempt:
Free Memory 21588K of 61101K Total (35%)
Any ideas on what is preventing the project from deploying?
Prior to this, the bench top testing was completed successfully, all posted software upgrades were completed and all network settings have been properly set prior to attempting this.
(6,364 Views)
When you say you never get a complete message, does that mean it stays there forever? Or is there an error message?
What is your network connection? Have you tried it wired? Do you have a firewall that could be getting in the way?
(3,059 Views)
Turning off the firewall seemed to remedy the problem   Everything is running fine.
Thanks sciencewhiz
(3,059 Views)
