FIRST Robotics Competition Discussions
Does FRC/CRio support SPI interface
Hi
Is there a way to implement an SPI interface on the FRC CRIO.
I only need TX data, but I'd like to be able to generate a block of data and just send it in the background.
Thanks.
Phil.
Get a life? This IS my life!
(4,947 Views)
Yes.  There is an SPI API in at least LabVIEW and C++ (not sure if the Java port ever happened).
(3,440 Views)
Thnaks
I found it buried deep in the WPI library.
Looks like I can adapt it for efficient block transfers.
Now just to figure out where to connect to it...  DSC or sepparate DIO module.
Thanks.
Phil
(3,440 Views)
Just connect it to the GPIO lines on the digital sidecar.  The open requires you specify which lines you are using.
(3,440 Views)
