FIRST Robotics Competition Discussions
Does LabView FRC 2014 run in its entirety in OS X
Hello all,
Just wondering if anybody happens to know if all of the components of the updated LabView FRC 2014 can run in OS X. If not, I would be able to install it in a VM, but in the event that is can run in OS X, it would be easier setup.
Thanks!
(7,014 Views)
Accepted by topic author _Overlord_
LabVIEW FRC is only supported in Windows. While LabVIEW can run on Mac OS X, things like RIO, Real-Time and Vision are PC Only.
(3,932 Views)
The Java FRC programming environment is supported on OS X, if you decide that programming on a particular OS is more important then programming in a particular language.
(3,932 Views)
