FIRST Robotics Competition Discussions
Driver Station problem after 'nicyapi.dll' fix
The Driver Station, after runing the nicyapi.dll fix, has the DriverStation application that appears at the bottom of the Driver account. But the Dashboard application dosn't appear at the top of the screan. How should I go about fixing this.
(4,913 Views)
In the setup tab, if remote dashboard is selected, select local dashboard and restart the driver station.
If that isn't the reason, there's also been some problems with the driver station installer not updating everything. Run the DS installer again and choose uninstall. Then run it again and reinstall.
(3,268 Views)
Thanks I will try it tomarow
(3,268 Views)
That did the trick. Thanks for the info
(3,268 Views)
