FIRST Robotics Competition Discussions
Error 6 when trying to build program on cRIO
When trying to build a standalone application following the steps on 'Using the FRC Framework' page 14 I'm getting the error below. The program I am trying to build is the simple motor control program as described in the training video. Can someone tell me what this means and how to fix it?
thanks,
David Clark
Team 1245
ERROR MESSAGE:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Generic file I/O error.
C:\Program Files\National Instruments\LabVIEW 8.5\resource\plugins\NewDialogFiles\ProjectWizards\FRC\FRC Templates\builds\FRC cRIO Project\RT CompactRIO Target (0.0.0.0)\FRC Basic Robot Deployment\c\ni-rt\startup\NI_FPGA_Interface.lvlib_NIFPGA Watchdog
(7,126 Views)
This is a known bug in the basic framework and will be fixed in the next LabVIEW update. You can run it just fine, but it won't build. The advanced framework works fine.
(2,911 Views)
