Please note that the content contained in this document is out-of-date for the current competition season. Please feel free to use it as a reference moving forward.
Problem:
I need to restore my classmate to it's original settings.
Solution:
In the Kit of Parts (KOP) you should have been given a USB Thumb Drive known as the "USB Restoration Key". This thumb drive contains all the files to restore your classmate to it's original state.
WARNING: This Process Will Erase All of Your Information AND Files off of The Classmate.
- With the Classmate powered OFF, insert the bootable USB Key into an available USB port. Do NOT use a USB hub, instead, plug the Key directly into the Classmate.
- Power on the Classmate and when you see the 2Go PC screen, press F11 once. A small window will appear entitled 'Please Select Boot Device'.
- Using the cursor keys, select the USB Key. It will likely be the second item in the list, beginning with USB:xxxx, where xxxx is the name of the brand and type of USB Key. (For Example, USB: SanDisk U3 Cruzer Micro 8.0). Do NOT select the USB:Generic device, this is not your USB Key. If two identical looking USB items show up, don’t worry this is correct.
- Once you've selected the first of the two USB Devices, press Enter. Allow the Classmate to boot from the USB Key. You will now be at x:\windows\system32>wpeinit. Be patient, it can take a minute or more for wpeinit to finish.
- When the restoration options screen loads you will be presented with 6 options.
- Prepare your internal drive <only>
- Restore the image onto your internal drive <only>
- Prepare AND Restore
- Exit to Command Prompt
- Exit and Reboot
- Exit and Shutdown.
- To do a clean restore, it is recommended to select Option 3: Prepare AND Restore. Type 3 and press Enter.
- You will be prompted to choose ‘Yes’ or ‘No’ to format your classmate. Type Y and press Enter. Be patient, the format process will take around 30 minutes to complete.
- When you see the message ‘Full Classmate Restoration Complete’ press Enter to return to the list of restoration options.
- Type 5 and press Enter to reboot the classmate.
- Install the LabVIEW update.
- Install the Driver Station update.
These instructions can also be found in the following locations:
- In the document, 'DS Restoration Instructions.docx' , on the USB Key itself. But this document is an abbreviated version.
- On page 7 of the FRC Control System Chaper 1 – Introduction - Also less detailed than this document.
Ben Sisney
FlexRIO V&V Engineer
