Please note that the content contained in this document is out-of-date for the current competition season. Please feel free to use it as a reference moving forward.
This document contains the FRC 2012 known issues that were discovered during the 2012 season. Not every issue known to NI will appear on this list; it is intended to only show the severe and common issues.
| Source Forge Tracker ID |
Known Issue |
Workaround |
| cRIO Imaging Tool - Timeout error due to various network interface configurations |
| artf1436 | Setup Axis Camera Tool - Axis 206 camera loses communication after power cycle |
| Kinect does not work if Cypress IO has been set to Enhanced Configuration, but the board is not connected |
| Running the project has no issues, but building it fails explaining that it cannot save the Vision Processing VI in a bad state without a diagram. |
| If CAN is used in the Autonmous VI, the robot cannot transition to the Disable or Teleop VIs. |
Shouldn't the workaround for the imaging be disable (rathern then enable) wireless? It should also say to disable all other network interfaces.
That issue isn't always resolved by disabling wireless- on certain computers you need to enable the wireless to get it to work correctly. However I would just encourage getting the latest utilities update and avoiding the issue entirely
