NI has 2 installers for FRC 2017.
The "NI Software for FRC 2017" content contains industry standard versions of LabVIEW, Real-Time, Vision, PID, and the FRC Simulator. This content is available via download or on the NI Software DVD in your kit of parts.
The FRC 2017 Update Suite contains all of the FRC Specific content for LabVIEW as well as the Driver station and Utilities that ALL FRC teams will need to install.
Check the options below if you are not sure what you need to download and install.
Installation instructions are included in the What Should I Install? section below.
NI Software for 2017
NI FRC Update for 2017
The FRC Update Suite Password is &Full$team^Ahead!
Both the "NI Software for FRC 2017" and the FRC Update Suite will need to be activated. You can find your team's unique serial number on the back of the DVD envelope that is included all teams Kit Of Parts.
The serial Number should start with an 'M'
If you want to install software before you receive you kit of parts just leave the serial numbers blank and LabVIEW will be installed as a trial.
You can Activate LabVIEW after installation using the NI Licence Manager. (Start>Programs>National Instruments>NI Licence Manger
Download and Install all components of NI Software for FRC 2017
then Download and Install FRC Update Suite
then restart your computer
Download the NI Software for FRC 2017 and install vision only
Just download and Install the FRC Update Suite
The 4-slot and 8-slot cRIO controllers can no longer be used for FIRST competitions. But you can still program these controllers for use in demo robots. You will need to use the NI Software for FRC 2014 installer and the FRC 2014 Update Suite (links below). You will also need the serial number from your FRC 2014 Kit of Parts to use this software.
Download the 2014 NI Software for FRC
Where's the password for the update suite? Or should we use the same password as for the game and season manual? 2017 Kick-off was yesterday. Cheers!
[Update]: Never mind, it was indeed the same password as the game and season manual.
I installed the 2017 Labview program and the updates, but, I get the error code below when I try to execute. Any ideas on how to correct?
Exception: Unknown (0xC06D007E) at EIP=0x771EC54F
Probably the best way to troubleshoot that would be to give our support team a call KDRC606. They're available from 1-7PM Central at 866-511-6285 (Monday-Friday) Give them a call and they'll do everything they can to get you running smoothly.
You might get around that if you try these troubleshooting steps:
Imaging the roboRIO and Common Troubleshooting Techniques [link removed; article no longer available]
Look especially at section "The roboRIO imaging tool returns an error" and follow those steps. I usually find the NI-MAX step to reformat the one that fixes everything, but I suggest you follow the suggested steps in that order.
