This document describes the driver station for the 2018 FIRST robotics competition season. Read through it to learn about new features and functionalities introduced with this software-based driver station.
When you run the Driver Station Executable on a PC or start up your Classmate, you should see the following screens. These are the default Dashboard and Driver Station windows.
Default Screens: Dashboard (top) and Driver Station (bottom)
In the driver station window, you can see four main areas. The four areas are outlined in colored boxes in the following image.
Driver Station: Main Areas
Main Display (Yellow Box) – This area indicates for which team the driver station is configured. You can configure the team number on the Setup Page. This section of the driver station also gives you the battery voltage of the robot and has 3 LEDs that give you important information.
 LED  |
 Green  |
 Red  |
 Communications  |
 The Driver Station can communicate with the DS Radio, Bridge, and roboRIO.  |
 The Driver Station is unable to communicate with the DS Radio, and/or the Bridge, and/or the roboRIO.  |
 Robot Code  |
 The Driver Station can communicate with the Robot Code on the roboRIO.  |
 The Driver Station is unable to communicate with the Robot Code on the roboRIO.  |
 Joysticks  |
 The Driver Station can communicate with the configured joysticks.  |
 The Driver Station is unable to communicate with the configured joysticks.  |
Operation Page
The Operation page, shown above, contains all information about the current operation of the robot. On the left side of the operation page you can choose the mode of your robot to be either Teleoperated, Autonomous, Practice, or Test. After you select a mode, you can enable it by clicking the Enable button. After the mode of the robot has been chosen and enabled, you can then disable it by clicking the Disable button. If the robot is connected to the Field Management System (FMS), then this section will display information from the FMS.
Information pertaining to the run state of the robot is given on the right-hand side of the Operation page.
Diagnostics Page: Sections
Above you can see that the diagnostics page has been selected. This page contains the diagnostic information for all the connections to the driver station.
On the left side of the Diagnostics page you’ll see the Communications section. This section allows you to see with what portions of your control system the driver station is able to communicate. If the driver station is able to communicate with the listed item, then the item’s indicator lights up green. For troubleshooting communications issues, mouse over the item with which you are not able to communicate, and the driver station will provide troubleshooting tips in the Messages section.
Versioning information for the driver station and roboRIO image can be seen in the Versions section on the right side of the Diagnostics page. This information is important for troubleshooting and maintenance of the robot to ensure that the roboRIO and driver station have the latest updates.
The Diagnostics Page also contains buttons to reboot the roboRIO and to restart the Robot Code as well as indicators which show how much free RAM and disk space are available.
Setup Page
The Setup page is the third tab in the driver station. On this page you can configure the driver station for your team number, choose dashboard type, configure the practice round parameters, and choose your FMS protocol.
Configuring the team number also configures the driver station to be 10.xx.xx.5 and the computer to be 10.xx.xx.6 automatically (where xx.xx is your team number). This is done by simply typing your team number into the Team Number text box. You’ll know that the driver station is making these changes by looking in the top left corner where it says Team # xxxx. When it finishes configuring, it will list your team name in the top left corner. You can also use the drop down to select your roboRIO from the list. If you are experiencing a lack of communications, you might want to check that your team number has been entered correctly. The Driver Station will always try to find the roboRIO that corresponds to the team number.
Setup Page: Team Number Configuring
On the right of the Setup page is the practice round settings. Here you can manipulate the parameters for when you run the robot in practice mode. A description of these options and what they change is listed below.
The USB Settings page is the fourth tab in the driver station. This section shows which devices have been connected via USB to the driver station and their connection status. On this page, you can set up your joysticks for controlling the robot. If a joystick has been plugged in, it will light up green when you operate one of the buttons. Up to four joysticks can be connected to the driver station at one time. To know which position a joystick is currently assigned, press a button on the joystick and see which text lights up green. To configure which joystick is assigned to a numeric index you can click on the joystick’s name and drag it to a different position.
USB Settings Page
Power & CAN Page
The Power and CAN page is the fifth tab in the driver station. On this page, you monitor the status of your fuses, power faults, and CAN Metrics.
Messages Section
This section shows the messages and charts page. You can use the buttons on the right to view the message section, the charts section, or both. The message section displays error messages from the robot’s code. These errors are logged on the roboRIO, and you can view this log by clicking the Logs button. You can clear the messages in the Messages window by clicking the Clear Errors button. The charts page displays information that can be used to debug robot behavior. It has charts for battery voltage, lost packets, loop time, and CPU usage. You can also select how much history the charts have (either 12 seconds, 1 minute, or 5 minutes).
Charts Section
Messages and Charts Section
