Watch the entire stream here: FUN Special: FUNdamentals of LabVIEW Source Code Control
These slides accompany the fourth episode of the FUNdamentals of LabVIEW Twitch series on FIRST Updates Now. Episode 4 covers Source Code Control - a methodology to effectively collaborate on code across your team. It also contains ten helpful tips and tricks for improving your LabVIEW robot code and programming experience.
By the end, you'll be able to implement Source Code Control for both the standard LabVIEW robot project and a Command and Control robot project. You'll also have gained some helpful insights into how to program more effectively in LabVIEW, and how to utilize more features of LabVIEW to make programming, testing, and debugging easier and faster.
