FIRST Robotics Competition Discussions
Forward and Reverse on Spike for Motor Control
We want to use the Spike Relay to control a motor forward and reverse.
We are using Labview and have opened the Relays as Both Directions
The Relays are connected to the Relay output of the Digital Breakout Board
We can get forward to work just fine but using Reverse or Both Directions seems to have no effect.
Can you advise what we need to try?
(10,423 Views)
One thing that you could try would be to implement the replay example that is in the example finder.  Can you get that to work?  Verify to make sure that you are making all of the proper connections.  You can also check this forum post as well.  http://decibel.ni.com/content/message/15132#15132.  Let us know if you make any progress.
Brandon T.
(5,178 Views)
At first glance, your LabVIEW implementation looks correct.  I would do a couple of troubleshooting steps to see if it is the hardware or the software.  For starters, watch the relay outputs on the Digital Sidecar; there are LEDs next to them that indicate the Forward or Reverse signal being requested by the cRIO.  If the LEDs are operating correctly, I would double check the polarity of the signal wires from the Digital Sidecar to the Spikes.  I believe if signal wires are reveresed the Spike will turn ON in one direction but not the other.
Todd S.
Mentor
(5,178 Views)
Thanks. We never see a red led on the sidecar in response to a reverse command on any channel.
(5,178 Views)
Accepted by topic author MarkGryzwa3206
hey,
our team's sidecar has some red led in the the relay area. I think it is just broken. try a different digital side car
(5,178 Views)
Turns out it was a defective Digital Sidecar.  New one made it work.
(5,178 Views)
