FIRST Robotics Competition Discussions
Getting "No Code" message on Driver Station after flash
OK well i have been posting about many problems that i have encountered. This is yet another
When i found an update i forgot to install for the cRIO. I imaged the cRIO with the update 2.0 from NI. Then I re-flashed my code into the bot.
Then after it boots it says "No Code" where the battery output is.
Why is this happening??
I did do updates for labView 8.5 from labview. they are NI VISA 4.4.1 and NI RIO 3.0. Could this be what is causing the problem??
Then will I have to reinstall LabVIEW from scratch??
(8,481 Views)
Have you updated the driver station as well?
JeremyB
Jeremy_B
(2,921 Views)
Also, you shouldn't have NI-RIO 3.0, you should be using 2.4.1, which is installed with the FRC DVD.  The CompactRIO will have 2.4.1 on it, and it generally will not work if there is a version mismatch.
JeremyB
Jeremy_B
(2,921 Views)
